We've just moved into a "new" property, built in the 1950's.
The electrics will need some updating in the near future as theres a lack of RCD's and the main CU is an old Dorman Smith with the thermal-only breakers.
I'd like to have it modernised, and I'm probably going to have to get a full inspection done as theres some suspect wiring to some outbuildings that will almost certainly need redone, but my main question was about the main earthing arrangement.
A photo of the meter and cutout:
https://www.dropbox.com/s/nghhdy1j2uwzm1b/IMG_20130716_101410.jpg
The incoming supply cable looks like MICC or similar, i cant see it that well as its behind the meter board, but its copper clad and has a screwed fitting on the end, from which emerges two (rather thin!) wires, one goes to the cutout/fuse, and one to the neutral terminal on the meter.
The earth from the two CU's are the two grey (they've been painted) wires in the centre of the pic above the meter, which appear to be attached to a pipe clamp of the sort you usually see bonding water pipes, which is attached to the supply cable...
Is this a normal/acceptable way of earthing to the sheath of a supply cable? Or should i be contacting the DNO to have it upgraded/fixed?
Also the wires emerging from the MICC seem very thin compared with the meter tails etc, is this normal?
Cheers
Kevin
Cheers
Kevin
