Hi All.
I have just moved in to a new house, and am a little confused as to how the system I have works exactly and how I can adjust it.
SYSTEM:
Boiler Potterton Suprima 50
CL145 Water tank
Room stat
Programmable potterton control model EP2002
There is a small (5 Gallonish?) tank in the loft
Electric shower
I have attached some pictures.
The 'problems' I have are:
The DHW is roasting hot
The DHW seems to 'come on' on the timer, when you select 'on' for the CH
The questions i have are:
How do I adjust the DHW temperature?
As there are only 2 adults in the house, and we are only there in the evening and weekends, whats the best thing to set the DHW to do?
We have a cold fill washing machine and dishwasher, so only use the DHW for baths really, as often the electric shower is used. And the kettle used for any hot water in kitchen.
Would it be best to just switch the DHW manually a couple of hours before we need it? (I believe the warm up time is quite short on the water tank i have)
How exactly does the boiler and water tank work together?
I had a combi in my last house. What I dont understand is if I have a water tank that heats the water, why do I need a boiler? and Vice verca.
A couple of the newer rads are fitted with TRV, but the rest are not.
The room stat is in the central hall of the bungalow (with 2 rooms in loft) so is not a bad place or general temperature guide.
Sorry for the long post, but nay help would be appreicated.
thanks
SYSTEM:
CL145 Water tank
Room stat
Electric shower
thanks
