- Joined
- 19 Aug 2015
- Messages
- 13
- Reaction score
- 0
- Country
We have moved into a house with a solar heating array on one of it's roofs.
We were told it was operating and certainly the Suntanna 2 controller shows switches working and temperatures in the collector and storage tank going up and down with daylight.
System has a pressure gauge which is currently at 4 bar.
There is a worcester greenstarHE combi, run off an LPG tank.
Not quite sure if this is cold water fed or not, i.e. it maybe fed off the solar tank (which would make alot of sense).
When we turn on a hot water tap the water runs cold until the combi kicks in. I cannot seem to make the temperature in the solar storage tank drop by running taps - surely at night, when the collector temp is way lower then I should theoreticaly be able to drain it until it runs cold ?
The boiler shows the water temp on it's little LED and that currently reads 42, which is slightly more than the solar unit temps (collector is 39degrees and the tank is at 33).
How on earth can I tell if this is working or not ?
