Hi All,
Need some urgent advice.
I have a 45amp circuit which was used for a single oven and a old style hotplate hob. I am replacing it with an Induction hob rate max 7200w and a double oven rated max 4000w, with my calculation that takes max ampage to around 46amps, which is above the 45amp circuit I currently have. So do I need to bring in a second circuit or will the 45amp be fine.
Also if I use the 45amp Circuit I will need to split the feed to the hob and the oven, should I just use a junction box and if so what rating, as it currently has a 30amp junction box which did concern me.
Any advice would be appreciated as I currently have no Kitchen as I ripped it out this morning.
Rob
Rob
