What is the preferred method for door casings/frames where knock throughs are created into extensions?
The total wall thickness is 300mm.
Do you inset a standard casing leaving enough space for plasterboard and arc all the way around, or knock up full width casing (assuming its not hardwood and going to be white glossed...)
