Hello All
I am about to fit a new kitchen and have a few questions:
Currently I have 5 double sockets in the kitchen that are all spurs dropped down the walls from the upstairs ring main, I will need to move these and add 3 more.
I am thinking of using a 2.5mm cable (that used to supply an immersion heater) and from this converting all the kitchen sockets to a radial circuit protected by its own 20A mcb in the consumer unit. In total I will have 8 double sockets and the total cable run will be 10m from the cu to the last socket.
I know the best solution would be to convert it to a separate ring main but getting the return cable back to the consumer unit is extremely difficult without major redecoration work (which like an idiot I have just completed)
Is the radial circuit idea okay or should I run a new ring?
I will be installing 4 integrated appliances that mean that the sockets will be hidden behind the new units, is it a good idea to fit double pole switches in an accessible place just in case I have to isolate quickly.
The reason for asking is that the switches are going to look a bit of an eyesore and my initial thoughts were not to go this way.
I will also need to bond the new plumbing pipework, where should I tie in the earth cable?
