Hi i have bought replacement doors for my kitchen units, however, ther are 15mm too small compared to my existing carcases. Can i cut the 15 mm off the sides of the carcases at highest point, then replace with the top covering, and fit the new doors?
Wouldnt it be easy to take the doors back & get the correct size.
Im guessing you cant take them back, so if thats the case why not say that if not.Opps
I think you would do better to add an infill of 15mm under the worktop. But remember this will need to be the same thickness of the door, i.e. if the new doors arec18mm thick then the infill will need to be 18 x 15mm and if the new doors are 22mm then the infill will need to be 22 x 15mm.
I will do a drawing a little later to explain a little better.
for the wall units, a strip of that ornamental coving stuff they put on top of cabinets, but fixed to hide the gap. Or if you put a piece of 18mm sq, painted gloss black, to fill the gap, it will probably not be visible, and will in any case be well out of line of sight.
yeah, i hung a doot, but with it being gloss black, and the carcass is white, the 7mm top and bottom looked well wrong, will go for the infill, reckon if i by another plinth that would give me the wood needed for the infill
