New Kitchen Old problem.
31 Mar 2008
Cheshire
Alright fellas, hope you can help me,
My old cooker plugged straight into the double socket above my units, but im getting a new kitchen next week and new oven and seperate hob, it is a 13 amp oven and 3 amp hob, will I be able to put a socket off the ringmain for the cooker with a fuse spur for the hob and another spur for the extractor?
Im am unable to rewire a seperate cooker switch because my mains is on the other side of the house and the floor upstairs is all laminated.
Am I right in thinking that?!
Are you really a spark?? Probably not or you would know the answer.
From your post I assume you are having a gas hob and the supply is for ignition only.
So the answer is yes.
Well , this is DIY forum. But you should be aware that you must inform your local authority before doing ANY electrical work in a kitchen. That's if you are going to do it yourself (or attempt it yourself).
