Hi all,
I'm installing a new kitchen, starting from the floorboards up and I'm having conflicting advice.
Currently, there is nothing in the kitchen including no floorboards. I'm doing the kitchen up so I can eventually either sell or rent my house out.
Originally it had 18mm floorboards. So I can put down Vinyl flooring, I thought it would be better to put down plywood.
The kitchen is at ground level, on wooden joists, there was a slight damp problem below, which I've been sorting out, but it will still be slightly damp underneath the kitchen near the external wall, I've added a new damp proof course and extra ventilation and will finally add in an extra wall below my patio, where the
dampness comes in to reduce this problem. But I was thinking of using marine - ply, incase the dampness stays. Is this worth worth it or is there better ply to use?
I was going to use 18mm plywood, but my builder say 20mm will be better, is this worth it, I was thinking this with raise the level in comparison to the hallway
My builder says I should put the Vinyl flooring down over all the floor, but I was just thinking of putting it under the kickboards of the units and under the fridge , so if I rent it out and it needs replacing it will be very easy to do, what do you think?
Finally all kitchens leak at some point, my dad says I should varnish the plywood first for an extra layer of protection for the floor, will this be ok? and can I easily put on the Vinyl flooring afterwards?
Any help will be much appreitiated
yof
yof
