Hi folks,
I have cleared the two downstairs bedrooms to put laminate flooring. Both bedrooms had carpets and I recently noticed muold on the carpet under the ottoman bed and condensation/damp on the lower parts of the bed. I have checked the under floor vents which are open and air is circulating adequately. I can also even feel the draught from some of the gaps so . I am assuming the cause is warm air (in the room) meeting a cold surface (floorboards) and causing sweating on the surfaces of the bed/carpet/underlay and eventually the floor??
Anyhow, when I lifted the carpet and the foam underlay the floorboards felt damp. The gap under the floorboards between the ground is about 15 inch or so with signs of water in the soil etc. (please tell me if I should be looking at something else)
I was planning to cover the gaps with clauk, put an aluminum air bubble membrane then fibre board before putting on the laminates.
I have been reading on various threads on the forum and the net advising not to put a DPM on floorboards so not sure if I am heading on the right path. Is my aluminim insulation a DPM?
Please can someone advise what would be the best course of action in my scenario?
thanks in advance
thanks in advance
