Hi all,
I am wondering if anyone can help with a problem I have with 2 way switching.
I purchased a new light fitting for my landing which is operated by 2 switches (1 upstairs and 1 downstairs). Having removed the old fitting (and not noting the way it was wired) I was left with a problem!
I have 3 cables coming into the light:
Cable 1 = 1 red wire, 1 black, 1 earth
Cable 2 = As Cable 1
Cable 3 = 1 red, 1 yellow, 1 blue, 1 earth.
Normally when fitting a new light fitting I would connect the black wires (of cable 1 and 2) to the neutral terminal of the light, the switched live (of Cable 3) to the live terminal of the light, connect the earth to earth and connect all reds in a separate terminal block.
I tried this set up earlier today and managed to make a fairly large bang! So I am wondering whether anyone has any alternative thoughts on how it should be wired. For Cable 3 the red wire is permanently live, the yellow is live when switched and the blue appears to have no power.
I believe I went wrong by connecting both the blue and yellow of the switch wire.
Any thoughts are welcomed!
