New Lights and Dimmer
8 Jul 2010
Aberdeen
Hi there
I was wanting to fit 3 downlights in to the wall. The room is quite small and the only power source coming in to the room is a double wall socket.
I was thinking I could wire in a lengh of electrical wire to use as the feed for the lights and dimmer from the wall socket. But from there I have no idea what to do! If it was just a light with a built in switch or socket then it would be striaght forward.
However doing the 3 lights with a dimmer switch is a little hard. Could anyone tell me what to do or even direct me to a diagram.
Thanks.
Do you mean downlights? they usually go in a ceiling??
Diagrams for lighting wiring can be found in the WIKI here:
//www.diynot.com/forums/viewtopic.php?t=37582
You cannot come off the back of the socket straight into the lighting. You will have to provide a Fused Connection Unit first and put the correct sized fuse in it (3 amp, probably).
You can only do this if the socket is part of a RING FINAL circuit.
can you?
Yes, you and I know that there are other ways to do this, but I wanted to take a simple approach with the OP otherwise there will be pages of "experts" arguing the toss and poor old CG will just give up.
Lets just leave it like that and see if he knows if the sockets are on a ring.
Then we can take other options, if needed.
Is that OK with you?
Apologies,do continue.
So it has no electric lighting at all at the moment?
I've never seen a light with a built in socket.
I'm not taking the p*** - we're all going to struggle to understand each other if you don't get the difference clear in your mind, and misunderstandings could have unfortunate consequences
. . . . . . Switch. . . . . . . . . . . . . Socket
