I want to replace the linings and doors in our house as the doors themselves are beaten up and were very badly hung, not to mention the linings are fire damaged (previously painted over at some point).
When I went to measure up I realised these are between 'paramount' partition walls - i.e. two bits of 9.5mm plasterboard joined by cardboard honeycomb. As such they're very thin - about 57mm.
Currently there are 57mm wide 'Storey' door frames with glazing above the door. I'd like to frame and plasterboard over the top where the glazing currently is for a more modern look, then fit a new lining and hang new doors - I want to put 'Safe n Sound' core doors in.
Obviously I can't buy linings for this off the shelf, but my thoughts were to get the timber yard to cut down two linings to fit from one off-the-shelf lining. Walls are being skimmed so new width will be 57mm + 3mm + 3mm I suppose so I could increase the lining width up to 63mm (perhaps 65mm to be safe?) Thickness would be the standard 27.5mm which is what they are now.
The main thing I'm worried about now is whether these linings will be strong enough to take heavier doors? I think we're talking about 28kg. I suppose the main stress will be when the door is open at 90 degrees - but presumably that will actually be on the fixings to the partition wall? These walls have what I think is 38x38mm 'studs' at each end, so it would be fixed on to that.
Is this sufficient or is there anything else I could do to strengthen it up? I'm not in a position to replace the walls with proper studs...
Alternatively I thought I could reduce the opening by fixing 'door studs' from floor to ceiling alongside the paramount studs then install 27" wide doors instead of the current 30". However maybe it's not great to have narrower doors for bedrooms - also I suspect that falls foul of building regulations. On the upside it would also provide space for architraves - at the moment one side of the frame is right up against a return wall so there is no room.
Finally - if I keep it as it is, do I just fit architrave to the one side and top and butt it up against the wall?
