Fittted a new bath the other day along with a new mixer tap. I had to extend the old copper pipes and I used the 22mm pushfit items to do so.
The hot water feels perfect but the cold is low compared to how it was on the old taps which had seperate heads.
The hot water comes from a cylinder next to the boiler and the cold comes from a tank in the loft fed from the mains.
First thought was an airlock but using the technique someone said before about using the kitchen tap to force the water back up the pipework to free the air seemed to make it a little better but it's still not what I'd expect.
Then I read newer taps are designed for mains pressure but the taps list operating range of .5 bar - 3 bar which I imagine the gravity fed cold should make since it's up another level.
The common problem I read as low hot pressure due to the mains cold being too powerful so fitting a valve cured this, doubt this is the case with myself.
These are the taps.
http://www.victoriaplumb.com/Taps/C...Bathroom-Tap-Range/Matrix-Bath-Mixer_358.html
Cheers
Jonny
These are the taps.
Cheers
Jonny
