New Oil Boiler Help
21 Mar 2008
Argyll
So the old oil boiler has decided to shuffle off the mortal coil this morning, at least it made the winter, and has now left me with a potentially hefty bill to replace. It has done a good job and have no issues with the sizing of the boiler for the property (4 bed semi detached)
It is a Turco 2000 70/90 conventional boiler located in the utility room and I need a good replacement and have a coupe of questions if anyone can help.
1, What are the better makes out there for conventional oil boilers.
2, Would a boiler rated 18-25 be able to replace it or would i need the next size up i.e 26/32?
Its on a sealed pressurised system if that helps.
Thanks in advance.
I use Hounsfield and have been very impressed with them. You need to use a Whole House Boiler Sizing Calculator to work out what size boiler you need for your house
