Hi All
I am having a new outbuilding built next to the house to use as a utility room with central heating off of the house. It is about 2.5m x 3m so below the size requiring building regs.
The builder is suggesting that instead of building a cavity wall with blocks and quilted insulation between it would give us a bigger internal space if we have single block walls, battened and insulated with 100mm celotex then OSB board, plaster then skim. Apparently this meets building regs even though regs are not required.
Anyone see any concerns with this approach or does it make sense?
I appreciate any input.
Cheers.
Cheers.
