I have just replaced an old outside bib tap with a new one. The new one has a double check valve built in; I'm not sure about the old one as I haven't managed to unscrew it from the old wall-plate to look inside.
Two queries:
1) With the old tap, I was able to drain it by shutting off a designated stopcock inside the house and leaving the tap open. However, the new one doesn't seem to want to drain at all. Is the double check valve preventing water from just flowing out when it isn't under any pressure?
2) Given that I can't drain the new tap, and that the pipe burst because I forgot to drain it last winter , I guess I'm going to have to get some sort of lagging to prevent future bursts. What do you folk recommend for this? Is it necessary to put lagging around the body of the tap too?
Dave
Two queries:
Dave
