29 Minutes Ago
We are about to embark on some pretty major alterations to our bungalow to add a second story and modernise its appearce. With the facelift to the front elevation i intend to install a pond feature. The front garden slopes away from the house so i intend to build a series of 3 semi raised ponds with the top one feeding down to the bottom. See the very amateur visual of the kind of thing attached.
The construction will probably be blockwork with a white render to match the house and a slate paving caping. The corner few stones will be a few inches lower to form a an infinity style water fall into the second pond. The third section probably wont be a pond but a raised bog garden with the overflow from teh second pond feeding this.I want it to look fairly contempory
I dont intend the pond to have a heavy fish population, it is more for the feature itself and the planting, however i have no doubt that once i have it in operation the koi bug might bite just as marine fish did indoors (buy buy £1000's).
If i need space for filtration etc, then there is plenty of room behind the pond as there is a 1600mm wide section down the side of the house which is just used for storage at the moment.
Has anyone any advise on anything. I havent got a clue where to start as i have never had a pond before. What should i be thinking about, how should i build it, any design ideas etc etc. I am fairly handy so should be able capable of doing all the works. Hell, i am building the house, im sure the pond cant be any more difficult.
Thanks in advance.
Thanks in advance.
