- Joined
- 13 Jul 2024
- Messages
- 1
- Reaction score
- 0
- Country
Morning Folks
First time poster but long time reader, the info in this forum is excellent
I’m looking to see if it’s possible to tap into a lighting circuit in the loft so as I can connect a double socket to it, this will only power a broadband modem and a wifi mesh system so both really low power draw products , my ceiling lights don’t have any loop in loop out so I’m assuming it’s at the switch or a junction box somewhere.
I do however have a pull cord light switch in the loft for loft lighting , could I tap into the feed cable before the pull cord with a junction box and connect both the feed cable to the pull cord and to my new socket from this?
My plan was to run 1.5mm from junction box then into a 3amp fused switch then feed from that into double socket or I may just connect the flex from an extension cable to the fused switch does that sound acceptable.
I do have another option where I have a redundant electric shower cable no longer in use , this is 6mm cable on a 32amp MCB in the CU , could I use this cable drop it down through the ceiling terminate it into a 3amp fused switch then either connect my double sockets the outlet side of the fused switch or connect the flex of and extension cable to the fused switch load side.
Apologies for the long post, and thanks in advance for any help, which one of these would be the better option if any are doable, I can’t get to any outlets to run a spur off.
Thanks Stephen
Thanks Stephen
