Hi. After the combi boiler pump failed I was feeling pleased with myself for flushing the CH system and changing the pump head (Grundfos UPS2 15 60). I would have liked to have changed the whole pump because the pipe was a bit cruddy but access to the nuts was difficult. Overall though the drained water was very clear so I didn't bother with any cleaning fluid, just inhibitor.
It was a relief to have the heating on and get hot water again. However even with the room thermostat set to 30 the boiler switches itself off well before then (I can hear the thermostat dial 'clicking' at 20). It fires up again after a while but only for a few minutes before switching off. It's maintaining warm but not hot radiators. All have been bled and TRV valves are fully open. The radiator and hot water dials on the boiler are on max. I don't have a thermometer but the flow and return pipes are similarly warm to touch. The hot water is working okay. Does the pump drive HW and CH or just CH?
Before changing the pump I hadn't noticed a firing up problem but I knew the radiators weren't getting hot and assumed it was all pump related.
The boiler is a Halstead Finest Platinum (12 years old). I know it will need changing soon but I'm trying to eke it out through the summer. Any thoughts on the likely cause and what I can do to resolve it? Thanks.
