I have had to replace a seized Grundos CH pump with a Wilo gold 50, the problem is that when I have tried to get the heating back on, after filling and venting the system I have no flow of hot water to my rads. The pump is running as I can hear the noise change when the speed is changed, inlet and outlet valves are open, the motorised valve is opening when it should do, all I am getting is a hot pump and hot pipework around the pump. I have also vented the pump using the centre silver vent plug.
There is an arrow on the casing of the pump showing direction of flow, so the pump should be installed correctly.
Any suggestions would be greatly appreciated.
