Hi all,
I added a new rad this evening to our system and it does.....nothing. I installed it using a freeze kit if that makes any.difference? It's a 600x1200 single panel and both the old and new rad use 10mm copper pipe.
I used a t into pipes supplying another rad and now that one doesn't work either. If I bleed either for long enough hot water comes out. But that's about it. I Both have been bled.
Annoyingly if I shut the valves on the new rad off, the old one that I t'd from still won't work.
Our boiler is a Worcester 28cdi.
Hope someone can help. Many thanks!
Wes
Wes
