I have just added a radiator to our kitchen (there wasn't one before).
But it doesn't heat up. We have a vaillant turbomax combi boiler.
I basically cut the 25mm flow and return upstairs, put in two 't' reducers to 15mm and dropped two 15mm pipes downstairs inside a stud wall to the new radiator in the kitchen. Filled the the system back up bled all the radiators (which all work fine) but the new rad. just doesn't heat up. Is it possible to link into the existing system in the wrong place? Could the drop down to the rad be too long? (it's approx. 2m drop, 4-5m run in total) The rad. is a single 1600mm long, could it be to big?
The new rad. bled ok and the valves are fully open.
Any help would be much appreciated.
Cheers
Paul
Cheers
Paul
