New radiator pipes
14 Sep 2004
I have a couple of new radiators that are replacing some old ones and in new positions so I will be running new pipes to them and I have a few options to mull over.
It is in a ground floor room, currently exposed floorboards with a couple of foot underneath to the bare earth - once installed this floor will be covered with stick down LVT so pipework will be inaccessible. The 22mm feed/return pipes are in the adjacent room and I will be teeing off in 15mm.
1. 15mm Copper out of rads and through the floorboards - I was going to then elbow to 15mm speedfit pipe with push fit and then no more joins under that floor. I'm wondering if this is going to be OK (I have a coil of speedfit pipe already) or if I should really do it all in soldered copper?
2. One I've finalised the material what is the accepted way of fixing the pipe under a suspended floor? Many other pipes under the ground floor just seem to hang in mid air, some are hung underneath the joists with string. I need to cross the joists to get to the adjacent room - clip to the underneath of joists? Drill through joists?
3. What about insulating the pipes? If they are clipped to the joists do you just put small sections of foam on the pipe between the joists?
Thanks !
better than any plastic pipe when access is no longer possible. Check for leaks before fitting floor.
Insulation all the way and support the insulated pipe with these
https://www.screwfix.com/p/floplast-half-round-clips-68mm-black-10-pack/92850
ae235
