Gas2Air said:Is your boiler got the Kw to cope? How big is the conservatory? How big of a rad?
My advice would be to use an oil filled heater instead, the heat loss from a conservatory is huge.
inline isolation valves should NEVER be used on heating flow & returns,
the small bore will restrict the flow of water too much,
and also act as a sludge build up point,
feed 10mm microbore down wall
turn down lockshield valves on hottest rads to boost new heater.....
