Hi
I have just fitted 7 new rads & all the pipe work. The system is a combi bolier with a 2 pipe sealed central heating system.
All the upsatairs radiators heat up fine and 2 of the downstairs also do. I have problems with 3 of the rads.
The problem seems to be where I have a tee junction to feed 1 rad in one direction and the other 2 rads in the other, the pipe is hot going into the tee but only 1 of the pipes coming out of it is hot.
I have bleed these rads to remove any trapped air but this has not made a difference.
Have I pipped it up wrong should I have not split the pipe and kept one long pipe with only tee's off to feed a rad?
please help!
Max
please help!
Max
