hi all, got a really irrittating problem with 2 new large tall column rads that I've installed onto an existing system - combi boiler vaillant 30kw. The problem is they don't heat up the rest of the rads on system work fine including a small column rad in the same room as these two! if I turn all other rads off in house I can get one to work perfectly and the other gets fairly warm but it's not right! so this proves the valves and pipe work are ok! There are 17 rads in total on system could it be the boiler is undersized?
any help would be great!
