I bought a new duel fuel range cooker last week to replace a knackered gas cooker, without thinking about the electrical implications. The kitchen currently just has standard plug sockets.
Being an electrical noob, it's not clear to me whether I can just replace one of the standard sockets with a double pole switch or whether a dedicate cooker circuit is neeeded.
The cooker is a Kenwood CK305, electrical instructions available here on page 36 : http://kenwood-cookers.co.uk/pdf/1104329.pdf
Excerpt from insturctions:
Any advice please?
With your new Fan oven it is possible to cook a variety of food using the 2 different cooking functions. The 2 positions, thermostatically controlled, are obtained by 2 heating
elements.
• Grill element 2200 W
• Circular element 2500 W
The appliance must be connected to the electrical network verifying above all that the
voltage corresponds to the value indicated on the specifications plate and that the cables
section of the electrical plant can bear the load which is also indicated on the plate.
It is recomended that the appliance is connected directly to the mains by fixed wiring,
placing a double pole switch with minimum opening between the contacts of 3 mm.
Alternative connection methods may be available as long as they conform to current IEE
wiring regulation.
Any advice please?
