I've had a heating engineer out today to replace the regulator pcb after he identified that was the reason I wasn't getting power to the 2/3 gas valve of c&m britony combi 80 which meant the heating worked but took its time and only a trick of hot water from dhw.
The pcb wash changed and this solved the original problem, any amount of red hot water but another problem arose, no central heating. The fan doesn't come on and the pump doesn't run.
The engineer but the original pcb on as a test and everything worked again, albeit on 1/3 burner only.
How often do you get a dud new pcb.
