New router
4 Jan 2004
Devon
I'm about to buy a new router. Almost certainly a Bosch pro version (with 3 year warranty). I anticipate that 80% of the time I will be using it free-hand as opposed to table mounted. Question is, do I buy 6mm capacity or 12mm? What factors should influence my choice?
I would go for a 1/2 router (not many cutters made 12mm) as it will have the power for larger cutters like panel door sets, cornice cutters etc. Also get one with variable speed as some of the big cutters should not be used at high speeds. Also worth getting a fine height adjuster as it makes setting up in the table a lot easier
The DeWwalt / CMT ones come with both 1/4" & 1/2" collets and are both based on the old industry standard Elu MOF 177E
Jason
Thanks, Jason. When I said 6 or 12mm, I was trying not to show my age :LOL: I really meant 1/4" or 1/2". For general manual tasks (e.g. shelving rebates and cross half joints (using straight bits), and straight mouldings (using bearing bits)), I'm tempted by the lighter weight (i.e. easier to move about). I'm not into door mouldings as I get my local joinery shop to make these up to order - it's more economic for me.
All the Bosch pro routers have soft start, variable speed, constant speed electronics, and depth adjustment to 0.1mm. It's just the collet size issue which I can't make up my mind about. I can't actually think of a task where I might want a 1/2" shank cutter - well, certainly not one that justifies another £80 on the price, anyway.
I agree that it is usually easier to balance a small router than a large one but you will be limiting your range of cutters to DIY/craftsman type. The thicker shanks do make a lot of difference as the rate of cut is much better as vibration is reduced and you can also use longer bits.
Jason
