Hi folks
We had a company build us a new garden shed February 2015, but we have a fair bit of mould appearing inside. Photos are here //www.diynot.com/diy/media/albums/shed.25655/
The shed sits on a raised timber deck foundation (see photo Shed0) due to the sloping garden. The top surface of the deck (not shown in the photo) is boarded out with 6"x3/4" planks as used for the new fence (see new fence in photos) and this effectively formed the floor of the shed. However, to seal the floor off from spiders etc getting in through the small gaps (2mm) between planks, I then overlayed the planks with 5mm thick plywood closely fitted. Mould/rot has been forming for a while now, mostly concentrated along the floor at the window side but also spreading along front and back sides of the floor.
Grateful if anyone can offer any advice as to how to remedy it.
Is it lack of ventilation to the underside of the floor (due to the external side panelling used to close off the deck)???
or is it rising damp, rising up the side panelling from the ground/grass?
You will see that it is stone chips (as opposed to grass) at the opposite side of the shed where the mould is negligible.
Thanks in advance
Thanks in advance
