Happy New Year.
I fitted a new double socket in the garage into which a freezer and tumble drier are plugged. This is more convenient than running an extension from another double socket elsewhere in the garage.
To connect the new double socket I wired it into the existing consumer unit which is already on the garage wall. The new socket is effectively a spur running from the RCD marked 'ring 1' and the RCD unit is marked 32.
I followed instructions I had read elsewhere and believe the work to be safe. I connected the usual colours correctly. Are there an issues here? The various sockets on the neutral and earth gangs were marked with numbers eg 1,2,3 etc etc - do all these numbers have to be the same for a new connection? The live I connected to the RCD marked 'ring 1' and is the same for the other double socket in the garage.
Grateful for any hints that might point to errors in work - the new sockets work fine and nothing has tripped.
walker88.
walker88.
