I have seen concerns raised about solid wood floors in bathrooms due to moisture.
I was originally going to lay travertine floor tiles but have decided that these are too cold - yes I know you can add underfloor heating but that is extra outlay and running cost. I like the idea of a naturally warm wooden floor.
Is this a total No-no in a bathroom or can it be done successfully?
Would a DPM over the concrete followed by underlay and a floating 20mm thick pine floor (glued at the tongue and groove) be OK if it were stained and sealed with 3 coats of Aqualac?
Will I still get the joints pulling apart due to expansion/constraction of the wood with the seasons and moisture content of the air?
What do I do at the edges of the room? Presumably I should leave an expansion gap but does this open the underfloor up to humidity and moisture?
Would engineered wood floor be better?
Am I really setting myself up for a fall here?
Any help much appreciated.
