new spout on kitchen tap loose?
12 Oct 2009
Lincolnshire
We've had builders in doing work and they fitted a kitchen including a new tap. Its not a monoblock I don't think as its got a rectangular body where the water connects and the spout sits on top of that.
Anyway the spout, not the unit itself is loose and you can wobble it, it doesn't leak buts its annoying. I've had a search but there is no nut or screw there holding it on and it surely can't be the washers that have shrunk as its new and not leaking?
if you turn it to the right or left it should pull off then have a look see is somethings missing
