I'm adding a secondary stud wall to the end of a room which is being turned into a kitchen. The wall is thin and backs on to my neighbours bedroom, therefore i am wanting to add this wall in, with sound proofing, to hopefully reduce some of the noise. The new wall will be about 2.5cm away from the existing wall.
The wall will be 4.4m x 2.65m high. I am planning on adding 18mm ply to the front to allow kitchen units to be fitted topped off with 12.5mm plasterboard. Also stud spacing at 600mm to fit in the sound proofing.
The questions i have is what is the correct size timber to use to build the stud work? i have read many different sizes and am confused as to what is best.
Also does everything else i have said make sense?
