I am wondering if anyone can shed some light on this situation. Renovating a 2 bed Victorian terrace in London. Currently the living area is all open plan with a small entrance area. We want to reinstate the corridor (up to the start of the stairs) by putting a stud wall up straight across from the entrance area to the kitchen. For 2 reasons, we'd like to making the living area feel more like a room that we can shut off and secondly because we fully intend to covert the loft in the future which will require this area to be closed off with fire doors in order for building control to sign it off unless we installed some form of mist system (as I understand it).
Our issue is that the supporting column for the rsj (installed before we purchased) projects from the wall in the corridor by 22cm. This creates a pinch point should we reinstate the corridor where the corridor might be under 60cm wide. This is obviously pretty tight especially getting furniture upstairs so to counter this we install double doors directly opposite as the access point into the lounge.
My query is whether this pinch point would raise issues with building control upon doing the loft? And with respect to double firedoors, can you just install two singles or is there an issue with the seal between them?
Local council weren't too helpful last time I contacted them
