Hello,
I'm framing an old granite room set on a flagstone foundation. There is no DPM installed as this is 19th century construction.
I'm planning to put down a full black plastic DPM before installing the eventual laminate floor but that won't be for some weeks after I frame the walls.
For the walls, I plan to put a strip of DPC under the sole plate(s). If the DPC is wider than the 4x2 sole plate, should the excess DPC be on the outside or inside of the stud wall and when I get round to installing the floor is it right to lay a DPM then simply lap it up the inside (room side) of the stud wall before plasterboarding over top?
I'm confused about how all these should interact in a retrofit situation where no DPM exists under the foundations.
Thanks,
JB
Thanks,
JB
