Hi all. I've decided to fit t&g floorboards to my suspended joist ground floor. I'm just at the stage of improving ventilation...then will be insulating between joists with Celotex 75mm.
Having read a little about available t&g floorboards, I've ended up a bit confused. The floorboards will be the finished floor and will be stained and laquered (water based). But just what should I be looking for regarding the floorboards, re quality and stability etc. I've read a little about whitewood and redwood...but not got a clue about the different grades and which suppliers might hold better quality stock. I'm in south west London, so hope you can recommend a supplier.
Secondly, regarding fixing the t&g...was looking at cramping and secret nailing, but interested in the tongue-tite screw..which looks pretty good. It's also a hidden fix, driven in like the nails, but has a smaller head to allow easy countersinking with no pilot hole required. Any thoughts or experience with these?
I've read some people glue the tongues...but most don't. So, is glueing the t&g required or not?
Thanks for reading. Hope I get some advice.
