new thermostatic mixer shower
19 Mar 2010
Clwyd
Hi i am installing a new thermostatic mixer shower and was after some advice> At the moment i have the cold water to my bathroom straight off the mains which is about 4 bar and the hot come from a cylinder feed via a header tank which is at low pressure.
Is it possible to put a pressure relief valve onto the cold to bring it down to 2 bar and have a pump onto the hot from the cylinder?
The usual method of installation is to run a cold feed from the same storage tank that supplies the hot water cylinder. That way, the hot and cold pressures are more or less identical. You can boost both with a twin impeller pump if required.
Thanks for that.
I understand that the method you have described is the best way to do it but would the way i described work?
I'm not too sure , but in theory if the cold mains pressure and the hot water pumped pressure are fairly equal you stand a chance.
You would probably need to check the operating specification of the mixer you were planning to use too. I imagine a thermostatic mixer may give better control than a manual one that just regulates flow.
maybe someone will be along soon with something a bit more definitive.
