hi guys, we have just had a total disaster of a bathroom fitted by a `professional`there have been so many issues with it but there's one which is a real show stopper - the thermostatic shower isn't giving out anything approaching hot water!
it has two controls - one which is a diverter and one for temperature control
we have a combination boiler which supplies hot water
when in the shower regardless where you turn the temperature control it makes no little to no difference
I believe the bath feed is the same pipe as carries the thermostatic shower feed so in my investigations I tried turning on the cold water tap on the bath and this improved the hot output from the shower a lot...
what can I do to fix this issue. I cant access the thermostatic mixer because its been put into the wall and it tiled over, the same applies to the pipework under the bath. there has to be a solution to this somehow?!?!
