Hi, I am currently renovating a whole house, and the walls aren't great.
In some rooms we have taken the paint off with a scraper, filled holes/gouges etc. then new mist coat followed by paint. The walls look OK, but you can see the filled areas unfortunately. Also, where we have filled, once sanded the mist coat didn't take the first time around the areas we had filled and sanded (I now know this is because as we have sanded we have polished the wall too much for the paint to adhere). The mist coat did go on with the second coat, but the walls still have sunken areas where the paint is thinner.
Basically for the other rooms I want to skim the walls instead (scraping paint takes ages, filling again takes ages! and after all that work they don't look great - soul destroying!)
Just after a bit of advice really, sorry if it is obvious
Firstly - trowels. I am looking at a lot of advice, regarding the size and make of trowel, have probably settled on a 13inch marshaltown trowel, but when I actually get the trowel, what should I look for? Difference between stainless and gold stainless for example, should the trowel be curved or dished, and if so which way? I have a small ragni trowel, but it has a rough corner that leaves lines everywhere! So I know I have to look out for one that doesn't have rough corners, but anything else?
Secondly - I will skim over the walls that have been painted already - so I assume just water down PVA and skim with multifinish. Do I need to do two coats, or is one OK because the walls have already been plastered once?
Thirdly - the small areas I have done already seem to go off very quickly, I was told to put on the wall, wait for a bit to firm up then trowel over but they go very hard very quickly. Someone told me the plaster was too old and 'off', this makes sense but could there be another reason as well? How long should it take to go firm - half an hour, two hours?
Finally - I will practice on some old plasterboard offcuts I have - fundamentally is this the same as skimming over the walls I have now (thermalite - concrete render and then plaster). Also, any other advice you think I need to know!?
Thanks in advance
Thanks in advance
