New toilet and semi pedistal basin
JAW
1 Nov 2007
Lancashire
Hello All,
I have to move the connection to the 100mm waste pipe about 90mm. The new toilet has a 90 degree connection and the current hole position (pointing upwards) will need extending and rotating about the axis of the vertical soil pipe.
Anyone else had similar experience ans what did you do?
Also, my semi pedestal sink fastens to a block wall. I have about 15mm of plaster on it so I don't envisage a problem running a 32mm waste pipe buried in the wall for clean lines. Can you get 32mm flexible pipes from the drain?
I will tile all the bathroom before any installation but need to have my buried waste and feed copper pipes in place first.
Regards
Rotating a pipe about its axis doesn't achieve a lot.... eh?
Flexible waste pipes are weak big and horrible, and clog up more easily. NB you can only take 32mm 1.2 metres.
