The new loo I'm trying to fit is leaking at the pan connection - I've just fitted the third (different brands of) connector, this one seems the tightest yet, but there is still a slight leak after flushing. The pipe connection is good, it's nice and straight, nothing strained or stretched.
I've fitted various types of connectors over the years and have never had this problem, the only thing I can see is that is causing the leak is that the outlet on the pan is not very well glazed and isn't completely smooth, but doesn't seem rough enough to be an issue. I know you aren't meant to apply any type of lubricant or sealant to the pan, so I'm a bit stuck as to what to do next - other than look for an even tighter fitting connector!
I was just wondering if there was a standard trade solution to this problem, as badly glazed pans must be fairly common!
Thank you in advance!
