New TRV, which end?
2 Nov 2011
Kent
I just fitted a new TRV to the rad outlet for convenience and because it’s reversible flow & the instructions allowed it.
The rad warms up fine but will it be as efficient as fitting the TRV to the inlet? Do rads with TRVs need balancing? If so can a rad with the TRV on the outlet be balanced & how?
no difference in efficiency and if you need to balance the rad use the lockshield on the other end, the only reason trv`s used to be specific for positioning was a noise issue when it was trying to close
Thanks ianmcd
I thought balancing was achieved by opening the inlet fully and restricting the outlet to the rad with the ls until the correct temp drop was achieved. How might I do this with the ls on the inlet? Is balancing necessary at all with TRVs?
Thanks. :confused:
You may have thought that but if you think again then you will realise that its the flow through the rad that you need to adjust.
That can be done on the lockshield because everything is in series.
All rads need balancing and its done with a TRVs fully open.
A TRV better senses the room heat if mounted on its side and better still if mounted on the cooler return.
Having said that, without a better reason ( access, cooler end of room etc. ) I prefer to fit TRVs on the flow.
Tony
Slightly off topic......
How would I install a TRV if I want both TRV and lock shield on the inlets of one side of a radiator? I need to do this to make the overall width less than normal.
You can't.
Unless the tapping for the valve insert is part of the rad rather than the little round ball welded on the back.
If it is all one piece you can create an injector tube.
Not quite sure I understand your reply, when I look at my radiators the top inlet where the bleed valve is fitted looks identical to the TRV inlet. So I imagined I can fit both valves on just one side of the new radiator....
I know what you want and I know how to do it!
You need a 1/2 male to 15 mm compression elbow into the rad at both ends.
Then a straight line lockshield and similar TRV so they end up vertical with the knob under the rad controlled from the inside.
Tony
