we have had a Gledhill 300litre unvented Cylinder installed by a G3 installer
The problem is when we are in the shower and if someone opens another tap or flushes the toilet the temperature changes in the shower which is dangerous for the kids and adults - is this because it’s not a thermostatic shower? Although we never had a problem with this shower when it was vented system with a pump?
However the biggest problem we are finding is for example if we run the hot water to fill the bath the other outlets for hot nothing comes out - so if someone is in the bathroom then they can’t wash their hands if the bath is filling?
The Gledhill docs says it needs 3bar pressure to operate but our installer said that our 2bar pressure (he said it was 2.5 bar at non peak times) would be good enough and our flow rate is 14litres
We had a new water main fitted 3 years ago (blue pipe 22mm?) and enters the house under the kitchen sink via an insuduct blue plastic pipe but straight after the stopcock it goes into 15mm copper and is rerouted around the house until I suppose it reaches the room where the cylinder is - is the 15mm what the problem is?
Should we extend and move the water main the 3 metres so it starts in the utility area and a 22mm feed can go into the Gledhill cylinder
