I have a new front door of the uPVC type.
Whilst it has been adjusted well with a good seal all round when closed and handle lifted there is a tiny Gap between the door and seal on the hinge side between the top and middle hinge.
The hinges are adjusted so that the seal near the hinges is good and tight. If I adjust these so it's even tighter then the door is a bit more difficul t to close.
It's as if the door or the frame is slightly warped alhough it doesn't seem to be.
The only possible solution I can think off is to add an extra hinge between the middle and top.
Any experienced people know of a better method?
Cheers.
Cheers.
