My Biasi has been costing me a hundred quid here and there since moving in 2 years ago.
First off the air pressure switch was suspected and it turned out to be debris build up on the venturi.
Any competent boiler engineer would always check the venturi before changing the APS. I hope you did not pay your nupty for an APS which was not needed?
Yep, paid him good money. Yellow Pages hey! So I have a perfectly good working spare APS if anybody wants it..will post it free as well.
Recently I've needed to turn on the DHW to get the CH to engage..suspected ignition box which turns out to be a misaligned flue fan.
It's also a struggle to get a decent hot bath which is still not really understood after a Kamco clean.
You have not made this very clear. The ignition PCB does not know what the heat is to be used for. Poor DHW is usually a partially blocked plate heat exchanger. If you have to turn on DHW before the CH will fire that implies a flow switch problem which is often a blocked CH circuit or a failing pump.
My fault here. There are 2 issues: The DHW does not get that hot - plumber said the heat exchanger probably needs descaling, which I except.
I cannot imagine how the fan can ever be misalligned! If it somehow was it must have been from when the venturi was cleaned after wrongly replacing the APS
I think you may be right that it could have been poorly reassembled. It was my good friend who misdiagnosed the APS.
My decision to replace was also helped along because of a very new arrival to the family which means the wife & little'n will be home all day. All this coupled with peace of mind (3 yr warranty) and the hope of lower gas bills (modulating Vaillant rather than constant full throttle from the Biasi).
I am sorry if I sound rather patronising but that is total nonsence! The Biasi is a fully modulating boiler and the burner pressure modulates from 1.5 mB to 10.5 mB. Of course if your nupty has misadjusted it then it will not be working as intended!
Fair enough - I don't know about modulation.
It's a big investment but I honestly can't wait to retire the pesky Biasi. What's probably most annoying is knowing it will need more expert trouble shooting in future which never quite hits the spot. Not that I can blame plumbers - it's obviously just a black art!
Biasi 24S/28S are very simple boilers and any competent boiler engineers will have no difficulty. Of course if you employ a nupty plumber then you only have yourself to blame!
How do you spot a nupty?
Thanks for the advice to power flush and re the cleaning gizmo.
If the hot water output is adequate then I cannot see any good reason for replacing your existing boiler.
How much money should you throw at something that's 10 years old and seems to be failing regularly. Granted the new machine may also give grief but surely the odds are reduced.
The Vaillants are towards the leading edge of domestic boiler technology and few installers can do anything other then fit them on the wall. You already have had a nupty fiddling with your Biasi to the extent that you now want to replace a perfectly good boiler. Vaillants are much more intolerant of nupties than Biasis!
The Vaillant will save up to 12% of the gas bill but the installation cost will take 10-20 years to recover based on that saving.!
Thanks Tony, I plan to track useage cost of the Vaillant and compare to my Biasi so will come back to this post sometime.
Tony
