I need to connect a 40mm waste pipe for a washing machine into an existing 65mm cast iron drain pipe. The new waste pipe will come out the wall on the ground floor to the left of the existing drain pipe:
The existing drain pipe goes into a concrete base:
What is the easiest way to do this?
1- Cut the cast iron pipe & connect to it?
2- Replace the cast iron pipe with plastic?
3- Dig through the concrete?
4- Put the waste pipe through the inspection chamber??
5- Else?
Cheers
5- Else?
Cheers
