new zanussi zce7550 electric cooker
29 Jan 2007
Shropshire
hi,
just got new cooker and went to connect it up after disconnecting my previous cooker and found that the terminals at the back of the new cooker have a live and neutral with just a small nut and washer and square metal plate behind, the earth is further up and over to the right,
i found it very awkward to connect to the small bolts and room is tight so i connected behind metal plates to make a better contact,is this ok and safe?
or should i revert back to trying to tighten the small nut and washer directly onto it
anyone who can help please :)
ps: cooker does work but ceramic hob swithes on and off and i don't know if this is normal or a fault or my method of wiring,previous cookers have had terminal type screws and worked fine. cheers
