newbie - shower question
12 Mar 2008
Surrey
Hi there
I am about to attempt to fit a mixer shower into our bathroom. the wall i am going to run the pipes in is brick. I know i am going to have to cut two channels in the wall for the pipes.
My question is to i lag the pipes with anything??? when i have or haven't done that do i plaster over the pipes or cover them with plasterboard and then tile????
what would be the best/easist thing to do????
HI
make bigger channel use 22mm plastic pipe to prevent pipes from corrosion,etc then plaster lightly over it
thanks for the tip. i just want to double check do you mean just use plastic pipe or use copper pipe and put it inside the plastic pipe???
thanks again
